Page 1 of 2
Polished Brake lever Disc Brake
Posted: Fri Oct 16, 2009 2:14 pm
by Mr Ed
Have a black lever on my master cylinder. Anyone know anywhere that you can get chrome/ss/polished levers to replace the black lever????
Re: Polished Brake lever Disc Brake
Posted: Fri Oct 16, 2009 2:57 pm
by chippy
just take it off and get that one polished or chromed, or cheap way just polish it yourself. I did it with very fine paper and then autosol metal polish
Posted: Fri Oct 16, 2009 3:06 pm
by sydduckett
yeah agree with the above its only a coating you will be able to get it off and polish it up quite easily. Just borrowed a mates bench based polisher, its the nuts......
Posted: Fri Oct 16, 2009 4:18 pm
by cezeta
Posted: Sat Oct 17, 2009 9:13 pm
by TS1-200
Simple, strip off the coating with nitromoors paint stripper, then polish with solvol Autosol, its easier with an electric buffer tho.
Posted: Sat Oct 17, 2009 9:17 pm
by J1MS
If you use wire wool with the paint stripper it will help remove the paint. You can use the wire wool to mildly polish the alloy as well, if its a fine grade wire wool, it can leave a fairly decent finish prior to polishing.
Posted: Sat Oct 17, 2009 9:21 pm
by cezeta
buy the one in the picture for six pounds and do something less miserable with your time
Posted: Mon Oct 19, 2009 10:28 am
by Mr Ed
Posted: Mon Oct 19, 2009 7:23 pm
by corrado
Posted: Tue Oct 20, 2009 10:15 am
by Mr Ed
