Some Series 1 questions
Posted: Mon Oct 12, 2009 6:36 pm
by Dryballs
Hi all,
I've been dry building my series 1 to see what bits I'm missing, what needs fettling etc
How do series 1 stands bolt on? can you buy series 1 stands? or is it easier to drill some holes and put a series 2 stand on?
Are series 1 forks different where the little inner mudguard fits? I tried to bolt the guard in today and it just doesnt look like it will fit!
I'm sure I had some other questions, but cant remember them!
Thanks in advance
Dryballs
Re: Some Series 1 questions
Posted: Fri Oct 16, 2009 8:55 am
by Dryballs
Bump!
Come on... Anyone know?
Posted: Fri Oct 16, 2009 9:20 am
by cezeta
i was under the impression that the series 1 and 2 non frame breather models were the same thing all but the bars and horn casing. mine was as original prior to restoration and from the frame number the lcgb thought it was a series 2. the forks should be the same, i use servetta forks as the rake gives a slightly longer wheelbase (aparently) and the inner mudgaurd just needed the whole drilling to bolt the mudgaurd in like on a bicycle.
thats as much as i know....i know the answers to the questions that you couldnt remember though if that helps
Posted: Fri Oct 16, 2009 4:26 pm
by Arch_Stanton
The stand will be the same as any other Series1 or 2, the brackets you need are these
and are held with 8 M5 nuts and bolts, there is a matching splash plate, later models had one early models didn't.
All these parts are available remade from any Casa Lambretta dealer, Scootopia, Cambridge Lambretta,Allstyles etc.
There are also early and late forks, each had a different inner mudguard.
Early forks had thinner legs, but the inner mudguard bracket was wider and the mudguard had a "squarer" cross section.
Later forks had fatter legs ,narrower bracket and the more semi-circular inner mudguard as per Series2 .
Copies of the parts list here, http://www.allstyles-scooters.com/lamb_s1.htm
Posted: Sat Oct 17, 2009 4:11 am
by L4Lambretta
Mr. Stanton,
Do you mean that early S1's didn't have a splash plate? Mine doesn't, but I'd like one to keep crap out of the engine.
cheers
L
Posted: Sat Oct 17, 2009 7:21 am
by burridge01
My S1 has a splash plate
