jet 200 engine identification
Posted: Mon Oct 12, 2009 11:25 am
by joda
whats the easyiest way to distingwish a jet200 engine from other lambretta engines, its ment to be a 1975/76 model, frame number matches engine, but engine number does look a bit scratched and scraped at
just curious!
Re: jet 200 engine identification
Posted: Mon Oct 12, 2009 11:50 am
by Soulpunk
post a pic.
impossible to say without.
on servetas engin n° + frame n° are always identical.
Posted: Mon Oct 12, 2009 12:46 pm
by byron
longer rear shock mount, not sure when that came in
later ones had neutral light switch
Posted: Tue Oct 13, 2009 11:06 am
by Dimitrios_231
They usually have 3 black rubber plugs at the rear hub area,seen from the kickstart side.
Next to the gear selector they have a strange metal spot.
Inside the crankcase they have a 'Batman' :D symbol.
Posted: Tue Oct 13, 2009 3:55 pm
by leigh
Dont the engine numbers start with the number 5
Leigh
Posted: Tue Oct 13, 2009 4:39 pm
by totally scooters
The best way to identify a JET 200 engine is by the 6 digit number which is always in between 550001 and 567***. Lynx engines are also in the sequence 860*** or 880***.
The other points mentioned in this post are applicable to age/year specific engines. Basically early JET engines are identical to Innocenti ones (aparts from the casting marks and the 6 digit numbers). Middle and later production ones have the neutral switch hole above the gear selector + (sometimes) the holes for the rear brake rubber bungs.
Hope this helps. Perry
