rear brake hub, help!!
Posted: Sun Oct 11, 2009 3:48 pm
having problems with my rear brake hub on my TV175 original hub i think,brakes have been poor since i got it earlier this year. I've tried adjusting the slack up on the brass nut at the rear, as soon as it get warm the brakes start to bind. also wheeling it backwards seems to be free and then binds again on certain revolutions of the wheel. Been to MB and bought new pads,cable,cam,clips washers etc. Also lost a number of locking washers cos the stud seems to have worked loose and fell off. Anyhow spent all morning putting the the new stuff on and nipped to the bottom of the road to try it with hub bolt tight but no washer on and the wheel started to work loose,I know the washer is to lock the nut off but would the nut come loose that quick and work the wheel loose or could the hub be Knackered.
If the hub needed replacing which is best Italian or SIL which MB have?
sorry this goes on but not easy to explain!
cheers.
cheers.
