lammy front wheel
Posted: Sat Oct 10, 2009 11:48 am
by bawjaws
anyone got a diagram of a gp front wheel assembly (the spacer/nut setup really) reason i ask is because i changed the speedo drives on a gp and they arent even touching eachother, a wee gap between the brake drum and the hub, what size spacer between the hub and and brake?, thanks in advance....
Re: lammy front wheel
Posted: Sat Oct 10, 2009 12:34 pm
by Daggs
Take a look on Scooter Restorations site. They have exploded drawings there.
Posted: Sat Oct 10, 2009 12:46 pm
by dapper
Posted: Sat Oct 10, 2009 9:07 pm
by rog60
bawjaws wrote:anyone got a diagram of a gp front wheel assembly (the spacer/nut setup really) reason i ask is because i changed the speedo drives on a gp and they arent even touching eachother, a wee gap between the brake drum and the hub, what size spacer between the hub and and brake?, thanks in advance....
Check you put the internal drive (on the stub) the right way round. i.e. nylon drive at the end of the stub.
Posted: Mon Oct 12, 2009 6:40 pm
by bawjaws
cheers lads, turns out it was the wrong spacers, had to cut a couple of new ones doon, works a treat noo!
