when the lights are off, and i put the brake on, it lights
when the headlights lights are on, the rear lights and when i put the brake on, there is no change
when the lights are off and i put the brake on, the brightness is similar to that of when the lights are on, if that makes sence?
iam lead to beleve that the wires may be back to front??
when it had the filiment bulb in, i had a dim tail light and a dim brake, but both worked with headlights on or off
thanks
