Page 1 of 2
Removing bearing collar
Posted: Tue Oct 06, 2009 7:50 pm
by Bufficus
What methods are we using for removing the bearing collar from cranks Gents?
Re: Removing bearing collar
Posted: Tue Oct 06, 2009 8:01 pm
by J1MS
Bearing puller bought off Adam Winstone few years back now...
But before that a bearing track puller available from Machine Mart, but for this the crank needs to be out of the engine...
Posted: Tue Oct 06, 2009 8:08 pm
by byron
I generally carefully cut a slot with an angle grinder and knock it off sharply with a chisel.
The best way I have seen is by CSE. Chris has made a tool like pliers with a ring coller. Heat this end then quickly grab the collar, the heat transfers to the collar and it just slips off. Uses the same in reverse to fit a new one.
Posted: Wed Oct 07, 2009 8:25 am
by Captain Chaos
I've seen that at CS Jarv
It's a brilliant bit of kit isn't it? Simple, but very effective.
I use the grind/tap off technique, but the CS tool is definitely a great way to do this job.
Posted: Wed Oct 07, 2009 5:47 pm
by monkey boy
Hi
Any idea if these tools can be bought??
AL
Posted: Wed Oct 07, 2009 6:12 pm
by mark
ring him he probaly make you one
Posted: Wed Oct 07, 2009 6:36 pm
by Bufficus
Thanks fellas. I'll have a go at the grind/tap method I think.
Posted: Wed Oct 07, 2009 9:49 pm
by lambro63
any contact numbers for this type of tool,,,,,,, any photos etc
Posted: Sat Feb 20, 2010 8:40 am
by westburyst
hello,
i've gone for the grind and tap method as I do not have access to any of the tools for easy removal. but the tap ain't happening, collar is real stubborn. how hard? i do not want to hit it too hard as i do not want to cause any damage.
cheers
Posted: Sat Feb 20, 2010 10:38 am
by shocky
kettle stream and mole grips
