SR175 Carb Clearance Issues (22mm Dellorto)????
Posted: Mon Oct 05, 2009 5:01 pm
Just fitting a SR175 kit to my series 1 using a 22mm dellorto carb. I have previously fitted the longer 200 engine mounts but I can't get the carb on as the fuel banjo on the carb clashes with the engine mount
Has anyone had this problem and got round it? Is my only option to fit a smaller LI engine mount to the carb side?
If I do go down this route, would I have problems having a longer mount on the kickstart side and a shorter one on the carb side, should I fit smaller ones either side? Also would I be able to use either the long or short engine bolt, or would I need to get a special length one which is in-between the two?
