Rear strut dimensions
Posted: Sun Oct 04, 2009 9:59 pm
by sydduckett
Anyone got a layout plan with measurments for the floorboard struts on a series 3 Li. Have had to buy new struts and bridge piece and want to make sure all the gaps meet up. current ones have been re welded at some point and there well out..
Have been given a scan of what look like tech drawings but there in italian..
sef
Re: Rear strut dimensions
Posted: Mon Oct 05, 2009 1:15 pm
by dapper
Posted: Mon Oct 05, 2009 7:38 pm
by sydduckett
Dapper was going to pm you but may as well keep it on the thread. Took your pic into the welder tonight (had blown it up and sharpened as much as poss) and we still couldnt work out some of the numbers, which sods law were the ones we needed..... :flaming:
anyways if you could work out what the numbers are then its perfect, if not I guess we need someone else to supply them. The one measurement i need most is the one from the centre of the hole on the smaller first strut through to the centre of the first hole on the main rear stut.
If I have this then should be ale to set it up from there...
Ill post this question as a seperate thread and see if I get any luck....
Cheers fot the pic
Sef
Posted: Mon Oct 05, 2009 7:44 pm
by sean brady scooters
surely,all you need to do is to measure that distance on some legshields/floor boards....
Posted: Mon Oct 05, 2009 7:53 pm
by sydduckett
mmmm, (in a bond villan accent) you may have a point. But Have you seen my legshields..
Could give this a go but would love the exact measurmets for front and rear struts if poss...
sef
