Suspect GP rear hub
Frautzi
Hi all i'm in the process of stripping a 1970 gp for resto.. I got to removing the rear hub wich was a b**tard...and noticed these breake shoes were a bit odd...
i was wondering why they had an almost 2mm perfect wear band on both shoes...and spotted this
if you look at the edge of the hub all the splines have a notch at the end of roughly 2mm....
has this hub been put on wrong in the past which has not allowed the hub to sit far enough back causing the odd wear on the shoes...or is it supposed to be like this...
And is this hub now toast?
it may be a daft question but I've only had, and worked on LD's so far..
Cheers Jason
That hub is knackered and needs replacing. It shouldn't have those notches and it looks like it hasn't been located properly after the damage was caused and therefore incorrectly tightened. Just make sure you replace with decent quality and don't use one made by RAMP.
Looks like its been bolted on knackered spline matey, Id check the condition of hub spline chances are thats knacked as well fella.
Frautzi
Thought as much ...will check the drive spline tomorrow and post pics so you can give me some idea if it needs changing....
Where can i get a decent remade hub and how much will it cost...
thanks for the replies fellas
Jason
I recently bought one of shocky of here and its great quality..FA Italia one well worth buying great quality.
Lam46 wrote:I recently bought one of shocky of here and its great quality..FA Italia one well worth buying great quality.
:lol: guess what i needed one for a mate and had to buy him one at wicksteed
jem booth had the best ones i managed to knock him down to £40 right at the end i dont have his number but someone on here will the general price seems to be close to £50 and that can be for a new scabby lookin one or like mine a FA italia one shrink wrapped
Typical that steve..
les perry
Main scooter: GP 230 TS1
Jems home number is 01772 495577 although would pm through here (member1001) as he does not often answer phone
Les
Frautzi
Thanks for the replies fellas...much appreciated..was trying to get to wicksteed but the wife's 4 days over due and was complaining of back ache so had to stick around...
Anyway back to the topic ..here's the spline and it looks OK to me.. no obvious signs of damage ..what do you think..
andylaw7
looks okay to me ,possibly had the wrong cone on it at one time or not tightened properly .should of gone to wickstead and left her taxi money :lol: then again if she would of dropped while you were away you would only hear it for ever and ever and ever and ever .good luck with the birth .
    Users browsing this forum: Semrush [Bot] and 11 guests
