Yet another thread about "best tourer set-up"
Posted: Sun Oct 04, 2009 2:48 pm
This has been discussed a fair bit but I'm still struggling to get to a conclusion.
What I want is a RELIABLE mile muncher that can cruise along at realistic motorway speeds with a good spread of power throughout the rev range and sensible fuel consumption. So far the only fixed decision is that the carb will be a TM24 with a foam filter and a "normal" looking pipe such as an Ancillotti or AF Big bore. The gearbox is SX200 (Jet)
Being a tight b@stard, money is definately a factor but I''ll pay for something that really does the job.
Ideas so far
1) Tuned Indian Iron barrel, standard crank, cut piston. This is what I have at the moment and it goes pretty well but needs a new piston after some "unpleasantness" when I tried a different pipe that just didn't work out right.
Advantages - Cheap as chips, got me to Holland and elsewhere no bother
Disadvantages - I worry that it isn't quite up to higher speed cruising. A sustained 60ish with a bit in reserve for overtaking lorries is pretty much its limit. (Thats GPS speed not lambretta speedo speed)
2) Mugello 225 with 116mm con rod. £365 kit plus £120 crank
Advantages - Hopefully a bit more power and the Ally barrel should be more reliable than an iron one. Theoretically bolts straight on
Disadvantages - Might need further tuning work to make it as good as it can be. I used to have a mugello with a 107mm rod and it was very disappointing. Not that fast and quite vibey.
3) Mugello as above but with a 60mm crank £365 kit plus £165 crank plus adjustment to make it all work together (another £150 at a wild guess)
Advantages - promises to be a good combo with nice long legs for touring.
Disadvantages - definately not a bolt-on as it will need fettling to get the ports set up for the long stroke which will put the cost right up.
4) Rapido Classic £180
Advantages - good price
Disadvantages - I don't know anything about them and don't know anyone with one. Read mixed reviews regarding quality. Might need further fettling by a tuner.
5) Rapido Classic with 60mm crank £180 kit plus £165 crank plus adjustment to make it all work together (another £150 at a wild guess)
Advantages - Long legs like the mugello but cheaper
Disadvantages - I don't know anything about them and don't know anyone with one. Read mixed reviews regarding quality. Will definately need axtra work doing to it
6)RT220 from MB £616
Advantages - Supposed to work straight from box, very high quality
Disadvantages - HOW MUCH! For that price I could pretty much get a 60mm crank mugello including all of the additional tuning.
So there we have it. I like the idea of a longer stroke engine for the torque but is the benefit worth the money? The RT sounds good but stone me, at £100 more than an RB22 that's a hell of a lot of cash for a conventionally ported cylinder kit. Just how much better than everything else is it. Would a tuned, 60mm crank Mugello be better than an RT for the same money? Or are all these exotic combos a good way a spending a lot of money for marginal benefit over what I have now?
Opinions gratefully received.
Ideas so far
