Quality Speedometers?
Posted: Wed Sep 30, 2009 10:38 pm
by Jet200
Who sells the best quality standard speedometers?
The original on my Li 150 S3 has just given up earlier this year. I bought a replacement and it's done just 1,526 miles and packed in as well!
I know Jem Booth repairs them and I am considering sending him the original but have been told he's that popular there's quite a waiting list?
Re: Quality Speedometers?
Posted: Wed Sep 30, 2009 11:01 pm
by sean brady scooters
JEM has joined up on this site,but as yet only as a member,hopefully he will be along soon to answer all enquiries........
once he makes an intro post,he will be able to post if he so wishes,also he will be able to take full advantage of the facility of others to PM him directly....
in other words,hopefully ,soon you can get in touch with Jem on here so heres hoping that Jem mucks in.......
Posted: Wed Sep 30, 2009 11:09 pm
by storkfoot
I've got one of Jem's refurbished ones. Had it for over 4 years and done several thousand miles on it. The needle is rock steady, in fact everything works exactly as it should. But I've also had a lot of success by buying cheap old ones on ebay, and rebuilding them myself. They're a bit fiddly with the odometer cogs but it's not that difficult.
If you look for a bog standard 50mph speedo, they go quite often for less than a tenner. You can then stick any face on it you like as, lets face it, the actual speed reading is a work of fiction anyway
If you compare the quality of the internal workings of the original speedo, with the remade ones, you'll see why this isn't a bad idea
I suspect you'll find that Jem only refurbishes original speedos.
