Old carb replacement
After 50 years of faithful service,the original 23mm carb on my TV Series2 has given up the ghost
.Its just worn out in every aspect,including the threads on the float bowl assembly.I have been running it since 1989 with the 65mm piston conversion,and an Indian big bore pipe.Anybody out there running the same top end/pipe combination,but using a different carb set up??,if so,any jetting help would be appreciated,thanks...............Kev
