Through the tube?
sydduckett
Not sure if this has been done before on here, but looking for advice/ideas on how best to run as much cabling/wiring through the frame as possible?
If anyone has pics of this sucsesfully done on there scoot and can post them that would be excellent. I seem to have so many bloody wires and cables im thinking it would look a lot cleaner. The scoots in bits so no better time..... :bouncyeng:
Cheers
sef
carlos fandango
Have a look at cut downs and choppers 99% of them have them going through the frame :lol:
on my chop we drilled the frame in the appropiate places and welded tubes to hold the cables in this makes it easy to replace cable outers if needed. wiring is one wire for the headlight going to a small toggle built into the underneath of the bates for hi/lo
sydduckett
Any pics of this mark? Where did you weld the tubes exactley?
sef
rear brake line
throttle cable
thats all i have m8 ,cant take any at mo due to stupid woman driver
