Stator Checks and Modifications
Posted: Fri Sep 25, 2009 9:11 pm
by soulsurfer
Swapped out a bog standard SIL stator for a modified MB one, which I'd converted for DC, and want to use the std SIL as a spare. Apart from carrying out the DC mod, I don't really know my way around the stator plate too well, so what is there that I could or should I do to it to make it more reliable or just to improve it and what checks should I make?
Ta.
Re: Stator Checks and Modifications
Posted: Fri Sep 25, 2009 10:40 pm
by J1MS
If you went and bought new enamal coated wire then re wound the lighting bobbins, fitted new leads and connectors, re-rivited all the dodgy rivets that secure the earthing points, replaced the LT coil with a Vespa one, you would have a top quality stator... And for less than the price of a BGM.
Posted: Sat Sep 26, 2009 10:27 am
by soulsurfer
J1MS wrote:If you went and bought new enamal coated wire then re wound the lighting bobbins, fitted new leads and connectors, re-rivited all the dodgy rivets that secure the earthing points, replaced the LT coil with a Vespa one, you would have a top quality stator... And for less than the price of a BGM.
Are you serious?
Was it you that started a thread about stator rebuilding? I don't suppose you have the link?
Posted: Sat Sep 26, 2009 1:27 pm
by jonny snatchsniffer
and not only that, but you can use thicker wire to get more power, just dont forget to alternate the bobbings winding
Posted: Sat Sep 26, 2009 2:30 pm
by soulsurfer
jonny snatchsniffer wrote:and not only that, but you can use thicker wire to get more power, just dont forget to alternate the bobbings winding
soulsurfer wrote:I don't really know my way around the stator plate too well...
I'm gonna need a bit more help with this methinks
I like the idea of this challenge but have a few questions...
Where do I get the wire?
What size wire?
How do you alternate the windings?
How many windings?
Which one is the LT coil and what do I ask for?
Here's the stator in question...
Out of interest its says Steelbird on the pickup (trash or not?), is this also known as the trigger?
Many thanks
Posted: Sat Sep 26, 2009 3:17 pm
by J1MS
Yes have to agree with you. Thicker wire can be used for a dc conversion. I try to get around 60 windings per bobbin alternating Windings or reversing the position of the end wires to keep it in phase.
It's a trade off between volts and amps the wattage remains pretty much unchanged.
Posted: Sat Sep 26, 2009 5:01 pm
you alternate by winding the 1st 1 clockwise then the wire goes onto the next 1 and its wound anticlockwise and so on till all 4 are done
so basicly the wire goes from the stator earth/centre tap then round all the bobbins alternating as you go then off the last coil to yer regulator
the lt coil uses much thinner wire to get a higher voltage.
dont beedspeed do a rewind service ?
you can always fit a vespa one, i had a pk stator on mine
Posted: Sat Sep 26, 2009 7:40 pm
by soulsurfer
Cheers.
I'm gonna give it a go
I think it'll make more sense when I try it, especially as I've found the thread of the upgrade with pics from J1MS
http://scooterotica.org/tempforum/viewt ... tor#p15772
If I was to increase copper wire thickness on the bobbins, what guage should I use?
