Any Dealers Do Timesert Or Helicoiling
Posted: Wed Sep 23, 2009 5:35 pm
As above, does anyone know if any of the main dealers do timeserts or helicoiling, need a manifold stud thread hole fixinx inan ally barrel?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
its worth saying where you are as many of us have these kits.eadmr04 wrote:As above, does anyone know if any of the main dealers do timeserts or helicoiling, need a manifold stud thread hole fixinx inan ally barrel?
I'm in North Essex if that helpscezeta wrote:its worth saying where you are as many of us have these kits.eadmr04 wrote:As above, does anyone know if any of the main dealers do timeserts or helicoiling, need a manifold stud thread hole fixinx inan ally barrel?
if you can get round to hayes middlesex or post it then im sure either sugarlump or johnscone could do them for you. both only have time certs as they are the best.eadmr04 wrote:I'm in North Essex if that helpscezeta wrote:its worth saying where you are as many of us have these kits.eadmr04 wrote:As above, does anyone know if any of the main dealers do timeserts or helicoiling, need a manifold stud thread hole fixinx inan ally barrel?
Cheers Martin, it's M7, just threaded so won't need welding, hopefully. I'll try to get it timesert as it appears that most people reckon they're better.Knowledge wrote:Dom,
Will the hole ali weld? John Howe could do that, or my top welder chap near Adastral Park. Come to think of it, John Howe might have Helicoils. Do you need M6 (TS1/RB/Imola) or M7 (everything else)?
I guess you know that Paul T has M6 Helicoils......
Martin
Last time I went to see John Howe a couple of years back with a similar problem with a Mugello barrel he had some stepped studs. M8 one end M7 the other. Just drilled and tapped the barrel to M8 and replaced with the stepped stud.eadmr04 wrote:Cheers Martin, it's M7, just threaded so won't need welding, hopefully. I'll try to get it timesert as it appears that most people reckon they're better.Knowledge wrote:Dom,
Martin
