Whats in your tool roll ?
Posted: Mon Jan 19, 2009 1:09 am
by ricalnic
After years out of the scene I'll be back on the road again this year
Now years ago I had accumulated the tools that i knew I could achieve most roadside repairs with. Those tools are long resigned to the bin, so I though I would start a thread where I could appreciate what I should consider packing this year to keep me mobile. I'll start the bidding with;-
plug key
8/10/12/13/21mm sockets & wrench
8/10/12/13/21mm spanners
adjustable spanner
pliers
long nose pliers
prop stand
flywheel puller
flat & cross headed screwdriver
gear cable innner
clutch cable inner
solderless nipples
spark plug
woodruff key/s
length wire
connector block (ensure screwdriver fits)
insulating tape
spare fasteners/nuts/bolts/washers
headlight & taillight bulbs
what in yours ?
Re: Whats in your tool roll ?
Posted: Mon Jan 19, 2009 2:11 am
by byron
also in my toolbox, or carried somewhere under the panels :
length of petrol pipe
spare fuel filter
carb rubber
throttle inner
tube of loctite
wire brush for cleaning plug
the phone number for my insurance/recovery
and i keep meaning to bolt a spare CDI somewhere
Posted: Mon Jan 19, 2009 9:05 am
by noggin1969
AA card to get there and an RAC card to get back
Posted: Mon Jan 19, 2009 7:41 pm
by scooty
i carry also
some spare nuts and washers
and a couple of bolts
jets and needles
you may want to add a 17mm socket for the flywheel nut
Posted: Mon Jan 19, 2009 8:15 pm
by RinB
ricalnic wrote:After years out of the scene I'll be back on the road again this year
plug key
adjustable spanner
pliers
long nose pliers
prop stand
flywheel puller
gear cable innner
clutch cable inner
solderless nipples
spark plug
woodruff key/s
length wire
insulating tape
what in yours ?
All of above Plus
gas soldering iron
Flywheel holding tool
Stator
Pickup
CDI Ducati
Reed Petals
Gaskets
Drive side seal
Carb rubber
Fuel tap
Loo roll for that roadside dump
PLus alot more if on euro
Smiffy
Posted: Mon Jan 19, 2009 9:23 pm
by soulsurfer
Can anyone recommend a multi tool that doesn't cost a fortune or has it got to be Leatherman, if so which one?
Posted: Tue Jan 20, 2009 12:50 am
by coaster
I don't carry half that stuff but I do cary a multi tester and a spare CDI and regulator. LED rear lamp so don't need one of those.
That's for scooting around locally (within 50 mile radius), if I was going further I'd probably suplement the above. Agree that the flywheel puller isn't a lot of use without a holder.
Posted: Tue Jan 20, 2009 1:25 am
by scooterjet
I carry most of what has been previously mentioned but also a spare inner tube and bicycle pump.How come nobody carries an 11m spanner
for the brass nuts on a lamby exhaust? I have always carried a Vega chain to hold the flywheel as it fits nicely over the rear hub nut and flywheel fins.
Posted: Tue Jan 20, 2009 10:19 am
by TheSeeker
After running out of fuel and forgetting my wallet on a test run round the Brussels ring I now always have a 20 euro note in a plastic money bag in my tool roll.
As for tools I've got more or less what is listed above. I couple of screw nipples in different sizes always help too, that way you may be able to jury rig broken cables. I also carry a very small bike pump and puncture repair kit. Even though I have a spare tire behind the legshields, you never know, you may have to help somebody else fix a puncture.
Agreed though that a charged mobile phone and valid break down cover is probably the highest priority.
Ben
Posted: Wed Jan 21, 2009 1:06 pm
by coaster
Mention of bycicle pumps reminds me, I have a gas powered tyre inflator which I carry in my Vespa tool box, I bought it from Cycle Surgery, £9.99 I think, its very small and does actually work. Refills are £10 for 5.
Nice tip about the vega chain btw, who stocks them?
