pick-up no lining up on BGM and AF flywheel.
Posted: Fri Sep 18, 2009 4:38 pm
Hey Guys,
So I’m trying to install a BGM stator and Li taper AF flywheel on a bike. The pick up doesn’t line up with the trigger magnets on the flywheel. The pick up looks to be about 5mm too low. I know it’s common to have to remove a laminate or two to drop the pick up a couple of mm but I seem to have the opposite issue. Has anyone ever run into this issue before?
Tim
Tim
