Page 1 of 2
Small End Bearings Gap
Posted: Tue Sep 15, 2009 2:21 pm
by Bilko
There's a gap of approx 3mm here. Is this ok without shimming?
Re: Small End Bearings Gap
Posted: Tue Sep 15, 2009 5:03 pm
by MarkH
You need the 16x20x22mm bearing
Posted: Tue Sep 15, 2009 5:36 pm
by Bilko
Ok thanks.
I rang PM as I had got the crank from them, but the chap I spoke to said it's to do with the piston type supplied. I've measured the gap in the piston and it's almost 24mm. So would I still need to shim the piston?
Posted: Tue Sep 15, 2009 5:57 pm
by J1MS
Is it a Yamaha Blaster piston..??
Posted: Tue Sep 15, 2009 6:32 pm
by Bilko
No Jims.
It's for the RB250 Not sure of piston type. :( :oops:
Posted: Tue Sep 15, 2009 6:43 pm
by J1MS
Ive seen a couple of RB250 barrels using single ring Bultaco pistons...
Posted: Tue Sep 15, 2009 7:22 pm
by Bilko
2 rings on mine.
How embarrassing not knowing the piston. :oops:
Posted: Tue Sep 15, 2009 10:13 pm
by andylaw7
bilko had exactly same thing on my ts1 (still in current engine )and i was told by af it dont matter as long as the big end is shimmed after all where is it going to go .my concern was about uneven wear but was told not to worry about it ,tis the first time ive ever had a piston like this .
andy
Posted: Tue Sep 15, 2009 11:02 pm
by Bilko
Would it not cause uneven wear on the small end bearings as theres quite a bit of space for them to move sideways?
Posted: Tue Sep 15, 2009 11:04 pm
by red
I'm sure between us we could find some way to fill the gap ;) :D
