so when is the power valve going to be the norm ?
Posted: Tue Sep 15, 2009 11:01 am
by cezeta
i ve wondered for years why we dont have power valves, some have said that they cant be controled but this is not true so why do tuners stay away from the power valve?
Re: so when is the power valve going to be the norm ?
Posted: Tue Sep 15, 2009 11:32 am
by Avantone
I think the main reasons are expense, stud spacing (lack of room) and demand, as well as the technical hurdle of getting the PV, fueling and ignition curve to complement each other.
This is probably why when you see it, the whole lot (cylinder, PV, ignition etc) is grafted on from something modern where a factory has already done all the hard work and development.
Posted: Tue Sep 15, 2009 6:53 pm
by J1MS
Ground clearance could be an issue, its got to fit in-between barrel and stub. It might only put an inch into the equation but they are close to the ground as they are... It would be a good addition to a Lambretta, giving some bottem end back to a peaky motor...
Posted: Tue Sep 15, 2009 7:02 pm
by Ian Hepworth
Broady did a one off barrel using one and gave up on it in the end. He tried various springs, fixing the valve at various positions and all sorts and was generally disappointed with the results.
Posted: Tue Sep 15, 2009 7:25 pm
by Powolotti
I think heat (and it´s dissipation) is also a problem on aircooled cylinders on this position..
Posted: Tue Sep 15, 2009 11:53 pm
by RICSPEED
Ian Hepworth wrote:Broady did a one off barrel using one and gave up on it in the end. He tried various springs, fixing the valve at various positions and all sorts and was generally disappointed with the results.
Wasnt that one controled by exhaust pressure rather that a servo?
Posted: Wed Sep 16, 2009 7:27 am
by mark
i believe someone is looking at the this modification as we talk
