which lens pattern - CEV or Aprilia ?
Posted: Mon Sep 14, 2009 7:23 pm
by Piatti
Hi,
which back light lens do I need or order for this type of casting,
CEV or Aprilia ?
Also is there a gasket between the lens and the bulb holder ?
regards
Piatti
Re: which lens pattern - CEV or Aprilia ?
Posted: Mon Sep 14, 2009 8:06 pm
by soulsurfer
I think either will fit, hence the two pairs of holes, I have CEV on mine.
There is a plastic gasket in between.
Hope this helps.
Posted: Wed Sep 16, 2009 12:33 am
by RICSPEED
its the corrello (spell check :lol: )that wont fit as it is angled at the back
Posted: Sat Oct 24, 2009 9:45 pm
by rog60
RICSPEED wrote:its the corrello (spell check :lol: )that wont fit as it is angled at the back
Is that the one with the integral reflector..............
Posted: Sat Oct 24, 2009 11:07 pm
by RICSPEED
i think they all do dont they?
Posted: Sun Oct 25, 2009 7:59 am
by soulsurfer
Yes
Piatti, any use? :?
Posted: Fri Oct 30, 2009 12:10 pm
by Piatti
Thanks for all the replies, the actual light housing has two holes on each side so will accept either a CEV or Aprilla type lens.
The angled type is the one which wont fit ( corrello )
I re-used my original reflector which sits in between the light housing and rear light lens, this had
holes directly in the middle which indicated that I needed a CEV type lens.
There is also a rear lens gasket which goes between rear lens and reflector,
I'll post some pics up when i get a minute
cheers
Piatti
