Removing the Brake Pedal
Posted: Sun Sep 13, 2009 9:09 am
by middo
Hello guys
how do you remove the pedal from the frame? I have disconnected the cable and removef the clip that clamped the lose end of the cable etc bit I can't see what's holding It in place now.
I have an api series two lambretta.
Thank you in advance for your help!!!
Middo
Re: Removing the Brake Pedal
Posted: Sun Sep 13, 2009 9:13 am
by joespeed
there should be a circlip on the shaft if not a bolt (poss 10 mm spanner head)in the centre.the return spring will still be under tension take care,
regards
joe
Posted: Mon Sep 14, 2009 12:33 pm
by middo
Thanks for the advice Joe, I have taken everything that’s attached to the pedal but i still can't get it off. There was a bolt holding the cable in place which was then clamped to the pedal with the spring clip but I had already removed these
There is around a cm of play along the 'peg' that the pedal is anchored on but I can't get it off..
Any ideas to what I’m missing... Apart from a big hammer!!!
Thanks again!
middo
Posted: Mon Sep 14, 2009 3:15 pm
by dirtyhandslopez
Have you hurt your finger yet? Says in my Innocenti shop manual for S2/S3's that a bloody finger is an absolute requirement for rear brake pedal removal, page 39.
Posted: Mon Sep 14, 2009 6:11 pm
by middo
yeah I have a few cuts! So I'm doing something right... Anyone recomend a place to buy the book? Done a few google searches and there seems to be variations of the workshop manual.
Thanks guys for you help!
Middo
Posted: Mon Sep 14, 2009 10:33 pm
by rog60
Posted: Tue Sep 15, 2009 12:33 pm
by middo
rog60 wrote:if you've released the circlip on the end of the pedal shaft, will slide off.
I will have to have a close look. I could feel a groove for a circlip but i can't see/feel it. All the same colour rusty colour after cleaning..
Cheers i'll have a look tonight!
Middo
