Carb choice?
Posted: Fri Sep 11, 2009 8:32 am
by Lijohnny
I would like some opinions here to give me an educated choice ?. Spaco v`s Jetex. Li 125 with 175 conversion, no porting, 42 big bore. What jets etc etc. Your comments would be appreciated guys.
Re: Carb choice?
Posted: Fri Sep 11, 2009 8:59 pm
by rog60
I built one of these engines for a local guy at the begiining of the year. I used:-
A Jetex 22mm carb with the GP150 inlet manifold (has small engine block inlet stud fitting and will take a 22mm carb)
Jetting:-
150 slide (with cutaway at the back)
118 main jet
45 pilot jet
5899-2 atomiser
I used the Dellorto jets and atomiser against the Indian fitted ones.
Engine is currently being run in with no problems as yet and seems reponsive to the throttle. I also fitted a 16 tooth front drive sprocket to raise the gearing a bit.
However if you can get a Spaco version(Indian) of the 2/22 carb then these are everybit as good as the Italian ones but you should be able to use the above jetting on this as well.
Hope that helps a bit................
Re: Carb choice?
Posted: Sun Sep 13, 2009 3:05 pm
by Lijohnny
Cheer`s mate really helpfull thanks
