ON THE ROAD REPAIR TIPS (VARIOUS)
Posted: Thu Sep 10, 2009 10:02 pm
this topic is opened for "on the road" repairtips.
improvisation tips and easy to do roadside tips to reach the next destination and drive some miles / kms.
WORN OUT SILENTBLOCKS (large or small type):
needed: 1 little piece garden hose (1 inch/2,5 cm) , bit of medium grit paper
try to get a piece of 1 inch long garden hose from somewhere, cut a little piece off.
take engine bolt out, drop the engine carefully and stuff the little piece of garden hose from the inside in the silentblocks. can be that outer of the house is too fat, use grit paper to file it down. if the inner is too narrow, slightly grease the inside of the silentblock and warm the hose a bit (in hot water or carefully with a lighter).
with that you can easily drive another 500 miles somewhere.
its tested.
CLUTCH CABLE (INNER):
had this problem one time in italy.
vespa ones are too short for lambretta. the clutch cable for ape (piaggio) 3-wheelers have the correct length (ape 3-wheelers are still very common in italy. so you can ask everyone at every corner for a correct length clutch cable).
FORK COMPRESSOR / CLUTCH COMPRESSOR :
use a tension belt !
wrap around engine case with a compressing piece (small wood / metal piece).
strap between 1 fork link and upper U-bend of fork (crossover).
PLEASE ADD YOUR TIPS !!
its tested.
