Which Valves?
Posted: Thu Sep 10, 2009 9:09 pm
by Boo
Hi all got tubless tyres and rims fitted to Lammy dont think theyre Scoot RS ones theyve got Sterling stamped on the rim brought them from Classic Lambretta Notts.Im thinking of replacing the valves after reading some bad reports on here about them failing and want to know which valves to use,will the ones from Demon Tweeks fit?the original valves have a rubber seal on the outide and one inside of the rim with a thread and nut on the ones from Demon Tweeks dont have the thread and nut. Any advise please.
Re: Which Valves?
Posted: Thu Sep 10, 2009 10:24 pm
by lamblast
DONT THINK THEY WILL FIT .I THINK THE HOLE DIAMETERS ARE DIFFERENT THE SORT YOU HAVE WILL BE FINE RAN THIS SORT MYSELF FOR 4 YEARS ITS THE LATER RUBBER VALVES THAT ARE FAILING
Re: Which Valves?
Posted: Fri Sep 11, 2009 7:03 am
by Boo
Lamblast thanks for advice :bouncyeng:
Re: Which Valves?
Posted: Fri Sep 11, 2009 12:39 pm
by Nic
I have a few 90 degree 8mm valves if you need them.
Re: Which Valves?
Posted: Fri Sep 11, 2009 7:40 pm
by Boo
Nic thanks for the offer mate decided to keep original valves :bouncyeng:
