lighting problem
Posted: Thu Sep 10, 2009 5:36 am
by showmenshaun
i have just got the lammy on the road but have a Sleight problem with the lights.
when i hit the brake my headlight dims and looks like i am flashing to over road uses. this has caused some car drivers to pull out on me can anyone give me some advise how i can correct this fault.
cheers for any help on this..
Re: lighting problem
Posted: Thu Sep 10, 2009 8:04 am
by soulsurfer
Are you using 6 volt or 12 volt system? Which stator plate? LED rear bulbs help but in my experience not too bright on the Li type light housing.
Posted: Thu Sep 10, 2009 11:46 am
by jonny snatchsniffer
on the 6 pole stator (no battery) the brake light is a different coil to the main lights and shouldnt affect it.
what is your set up ?
Posted: Thu Sep 10, 2009 9:00 pm
by coaster
The dimming of the headlight is normal on 12v Indian electronic set ups. As Soulsurfer says, fit an LED rear lamp and the problem will go away. Just make sure you get one with LEDS sticking out to the sides as well ar to the rear.
A bonus of fitting an LED rear lamp is that you can fit a higher wattage headlamp
Posted: Sun Sep 13, 2009 9:08 pm
by showmenshaun
cheers lads the led worked a treat. cheers
