What jets
Posted: Wed Sep 09, 2009 8:17 am
by stine
Im running a gp 150 but have put a suzuki 190 kit on it and have a 30mm delorto carb and a 48mm clubman exhaust however it seems slugish in the lower end tried the 42mm and the top end just disapeared i know its main jet is 118 but unsure of the rest im prusuming it standard 30mm any ideas anyone . :oops:
Re: What jets
Posted: Sun Sep 13, 2009 8:21 pm
by rog60
I'm running a similar set-up Casa210, 28mmdellorto + 42mm clubman. It's a little rich at the moment but this is the carb set-up: The engine starts well, idles, but splutters on picking up the throttle and seems to rev out Ok
Main jet 118
Pilot jet 52 (needs to be 50 or lower)
Needle X7 (2nd clip from top)
Slide 40
Atomiser AV266 changing to AV264
You probably need to take the carb off and find out which jets etc you have and re-post them for a more accurate diagnosis? Hope this helps a little.
P.S. There is not a standard setting for the carb only as supplied by the dealer? according to what the original engine application was or was requested.
e.g mine was supplied for a 150 engine and had a 40 slide, X2 needle, 105 main jet and 55 pilot jet and AV268 atomiser............
