110 Yam Rod on a SIL 200
Posted: Sun Jan 18, 2009 11:05 am
by Lamaddict
I'm just going to build my top end. I've Yamaha 110 conrod in a standard SIL barrel with a standard size SR piston, I have the 3mm packing plate but the head is not skimmed so to get the squish I may have to put the packing plate on with gasket seal......
Has anyone tried this set up on a SIL barrel? Any tips?
Re: 110 Yam Rod on a SIL 200
Posted: Sun Jan 18, 2009 11:55 am
by johnd
Lamaddict wrote:I'm just going to build my top end. I've Yamaha 110 conrod in a standard SIL barrel with a standard size SR piston, I have the 3mm packing plate but the head is not skimmed so to get the squish I may have to put the packing plate on with gasket seal......
I use a packer on my RB with just loctite gasket sealer, no leaks so far.
Posted: Sun Jan 18, 2009 2:03 pm
by Diablo
When I use packers with no gaskets I use 1104 gasket sealer. Very good for gasketless joins.
http://cgi.ebay.co.uk/3-BOND-THREE-BOND ... 240%3A1318
For heads this stuff is the best I've ever used and I swear by it now. Its been stopping brit bikes leaking for years!
http://cgi.ebay.co.uk/Stag-Wellseal-Joi ... 240%3A1318
Posted: Sun Jan 18, 2009 3:36 pm
by johnd
cheers for that wellseal link i've been searching for that for ages!
Posted: Sun Jan 18, 2009 6:03 pm
by Lamaddict
Thanks very much for the feedback.
Which would you compromise the better squish or the lower port timings?
Posted: Mon Jan 19, 2009 11:31 pm
by Lamaddict
Anyone on my later comment?
