Scooter racing question about carburettor's..
Posted: Sat Sep 05, 2009 9:03 pm
I watched the racing last week in Anglesey...
What I wanted to know was with the poor weather, cold and high humidity... did any of the racers suffer any carb icing.... Because the conditions were perfect for it, High humidity and well below 22 degrees... Normally under the right conditions the carburation goes off song as the air speed is increased through the carb, this happening as the throttle is shut off usually slowing down from high speeds/revs on a partial throttle opening... Causing poor running until the throttle is opened up wide to slow the air speed through the carb.... I Just thought I would ask to see if anyone had suffered odd carburation because of this while racing last week....
