Anyone Using A 30mm Dellorto On A TS1?
Posted: Fri Sep 04, 2009 2:55 pm
by soulsurfer
If so which one and how is it going? Also have you used an EGT guage on it?
Cheers
Re: Anyone Using A 30mm Dellorto On A TS1?
Posted: Fri Sep 04, 2009 7:18 pm
by J1MS
A couple of the Liverpool lads have them on there scooters I think they are in the 20+ BHP but go a little better than you would think.. One of the lads John is off to Chiselspeeds tomorrow to get his on the Dyno as he has fitted a new ignition system and wants to know if it will work with Chisels Advance/Retard unit... So its getting done tomorrow... If I can I will try to get him to post the dyno print out or see if he will give me a copy... Dellorto 30 VHSH is whats on it... I will try my best...
Posted: Wed Sep 09, 2009 7:58 pm
by flatnacker
hi ive just built a ts1 motor im useed a dellorto vhsh 30mm it works great not had it dyno'd but its got loads of drive and about 85mph confermed by a car speedo so about 80 sitting upright....
Posted: Wed Sep 09, 2009 9:40 pm
by soulsurfer
Cheers flatnacker, how easy is the VHSH to set up?
J1MS, any news on your mate's dyno?
Posted: Wed Sep 09, 2009 10:41 pm
by J1MS
Found a fault with the engine. Reeds I think. It's goingback soon. Will let you know when it goes back down. But the ignition he had readspeed type off Electrix world wasn't compatible with the chisel advance retard. But I didn't think it would be as it's not regulated at the pick up as a standard electronic.
Posted: Thu Oct 01, 2009 3:21 pm
by soulsurfer
J1MS wrote:Found a fault with the engine. Reeds I think. It's goingback soon. Will let you know when it goes back down. But the ignition he had readspeed type off Electrix world wasn't compatible with the chisel advance retard. But I didn't think it would be as it's not regulated at the pick up as a standard electronic.
Hi Mark, any chance of finding out what jetting he currently has?
Chers
Mike
Posted: Fri Oct 02, 2009 11:49 am
by J1MS
soulsurfer wrote:J1MS wrote:Found a fault with the engine. Reeds I think. It's goingback soon. Will let you know when it goes back down. But the ignition he had readspeed type off Electrix world wasn't compatible with the chisel advance retard. But I didn't think it would be as it's not regulated at the pick up as a standard electronic.
Chers
Mike
Will try to find out, he said he would let me know when he was taking it back to Chisels, but I havnt heard anything. I will give him a call.
Posted: Tue Oct 06, 2009 12:13 pm
by Toddy
Using a 30mm VHSH on my TS tuned by Ian at Taffspeed in a series 2 jetting below mate
Carb Set Up (Series 2 TS1 225 Taffspeed) PT Dynod @ Chiselspeed
Dellorto 30mm Flatslide (Taffspeed) VHSH
Slide 50
Needle K32p2 2nd setting
Atomizer DQ265
Main Jet 160
Pilot 40
Choke 60
Posted: Sat Oct 17, 2009 1:43 pm
by T5BEST
Toddy wrote:Using a 30mm VHSH on my TS tuned by Ian at Taffspeed in a series 2 jetting below mate
Slide 50
Atomizer DQ265
Main Jet 160
Pilot 40
Choke 60
Hi Toddy,
What is your exhaust with this setup.....??
Thanks.
