Page 1 of 2
Finless Flywheel
Posted: Thu Sep 03, 2009 9:01 pm
by Bilko
Does anyone know who can take the fins off a flywheel?
Re: Finless Flywheel
Posted: Thu Sep 03, 2009 9:03 pm
by sean brady scooters
any local engineering shop with a lathe.........
or just drill of the 6 rivet heads yourself and so remove whole ally fin assembly from steel flywheel..........
Posted: Thu Sep 03, 2009 9:22 pm
by Bilko
Thank you Sean.
Posted: Thu Sep 03, 2009 9:43 pm
by red
Posted: Thu Sep 03, 2009 10:52 pm
by Bilko
Red, I'm that thick, I'd probably would have done that if Sean hadn't said to drill out the alloy part.
Posted: Thu Sep 03, 2009 11:00 pm
by red
Bilko wrote:Red, I'm that thick, I'd probably would have done that if Sean hadn't said to drill out the alloy part.
No comment
Posted: Thu Sep 03, 2009 11:54 pm
by burridge01
Posted: Wed Sep 16, 2009 2:50 pm
by Bilko
Does anyone know how much the flywheel protrudes from the mag housing after the whole fin assembly is removed?
Would appreciate it if someone could measure how much sticks out from the mag housing.
Posted: Wed Sep 16, 2009 3:21 pm
by coaster
Bilko wrote:Does anyone know how much the flywheel protrudes from the mag housing after the whole fin assembly is removed?
If you are worried about clearance for a plastic fan you could always pack it out with spacers to make sure it clears the housing.
Posted: Wed Sep 16, 2009 3:45 pm
by Bilko
Hello Coaster, no it's not for a fan, there will be no fan. But am I right in thinking from your reply that without the fins and fin housing, it doesn't protrude from the mag housing?
