Page 1 of 3
Hub/Damper WTF?
Posted: Thu Sep 03, 2009 1:37 pm
by Bilko
My hub nut hits damper when I brake.
What's going, what am I missing?
EDIT: I've put on new dampers in case there's some fault with them. :/
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 4:33 pm
by Bufficus
Are you using bottom damper brackets or proper links with studs?
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 4:34 pm
by Bilko
Links with studs.
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 5:21 pm
by shocky
does the shock run inline with the fork leg when you view it from the front
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 7:11 pm
by red ghost
Bilko wrote:My hub nut hits damper when I brake.
A rubber bush?
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 8:42 pm
by Bilko
The bush was ok. It came off when I was taking it off the stud.
Shocky, it seems straight. I do have a squint and my good eye is glass eye.
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 8:56 pm
by corrado
Oversized nuts on the front axle.? some after market ones are too big.
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 8:57 pm
by Bilko
They're dome ones. :/
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 9:03 pm
by corrado
I'm sure we noticed that Timbo had the same problem in France and it was down to oversized hub nuts. Forget what was done about it. Ah, on reflection it may have been the nut on his front inboard disc brake stud.
Re: Hub/Damper WTF?
Posted: Thu Sep 03, 2009 9:24 pm
by Bilko
That's ok Martin.
Cheers anyway. Maybe try stiffer springs.
