Tail Light Flickering
Jet200
My tail light on Li150 has started to flicker at high revs. Normal tickover is ok with nice bright light, however, when I start to rev it, it starts to flicker. Checked bulb connections and spring leaves connections underneath, checked earthing wire has good earth, checked connections to rectifier, all seem ok. :?
Any thoughts, suggestions
Try a new bulb, it sounds like that one is about to blow ;)
Jet200
OK, thanks for that, I will try another one but it is a new bulb. Will try another anyway
al-super3
You could try the conections in the head set cos the rear light is fead from there
Scream at me until my ears bleed
J1MS
al-super3 wrote:You could try the conections in the head set cos the rear light is fead from there
I think as Al says, this Might be the cause if you cant find any fault at the back light unit... Normally (if your colour coding on the wiring is correct) its fed from the black wire from the Ignition switch which joins with two black wires at the head light connector block One wire should be the Speedo bulb and the other is the feed to the back light...
lammydave
Al, I see you profile lists you as being 37 .... surely some mistake? :o :lol:
    Users browsing this forum: Amazon [Bot] and 6 guests
