lightened flywheel
Posted: Fri Aug 28, 2009 8:38 pm
by scootcoot
Hey ! if i was to get my own flywheel lightened , would i have to re-set the timing when puting it back on ?
Re: lightened flywheel
Posted: Fri Aug 28, 2009 8:59 pm
by starreem
If you didn't mark it before you took it off, yes. Otherwise if all else is the same, then no. Woulnd't hurt however to check it with a strobe anyway.
Posted: Fri Aug 28, 2009 9:15 pm
by scootcoot
I take you dont have to do any mods to the mag housing if its my own flywheel thats getting lightened ?
Posted: Fri Aug 28, 2009 9:19 pm
by sean brady scooters
if your happy with your timing as is ......then simply lighten your flywheel and refit...................
why would you think that flange /mag housing would need altering........?
by corrado
scootcoot wrote:I take you dont have to do any mods to the mag housing if its my own flywheel thats getting lightened ?
No.
Posted: Fri Aug 28, 2009 9:20 pm
by Avantone
The timing wouldn't have changed unless you'd removed the stator too.
Posted: Fri Aug 28, 2009 9:23 pm
by starreem
Correct. Lightening removes material along the outer edge of the flywheel on either side of the screws that hold it together.
Posted: Fri Aug 28, 2009 9:30 pm
by scootcoot
sean brady scooters wrote:if your happy with your timing as is ......then simply lighten your flywheel and refit...................
Read some threads on using the AF ones you need to modify the Mag housing ! was'nt sure if you had to do the same with lightening your own !!
Posted: Fri Aug 28, 2009 10:28 pm
by rog60
I think I'm correct in thinking that's because the AF lightened flywheel projects deeper into the mag housing necessitating reduced height stator bolts (and sometimes machining of the mag housing) ??
Posted: Sun Aug 30, 2009 1:08 pm
by shocky
the later ones have a shim fitted to raise the flywhel and trigger point
