TV 200 exhaust system
Posted: Thu Aug 27, 2009 8:30 pm
by eibarlad
Just building a touring 225 (rapido classic)with a 46mm wide exhaust port,the same as an early tv 200. Was going to use a 48mm clubman but would rather use a more conservative set up.What was the downpipe set up on a tv 200 to accomodate the exhaust port.Also
would using a standard exhaust with a 20 or 22 dellorto hold back the potential of the engine as a tourer or help it in terms of lower revving reliability
Re: TV 200 exhaust system
Posted: Thu Aug 27, 2009 8:45 pm
by bristolmod
As I understand it, the downpipe section for TV200 was the same as all other S3's
The silencer itself was a specific unit numbered 19618060, although I believe this was dropped sometime during TV200's production run, and a "common" exhaust was used for all S3's (possible noise regs?)
My wife also thinks I need to get out more.......................
Posted: Thu Aug 27, 2009 9:04 pm
by J1MS
If you speak to Ray or Ben at AF's I think they will tell you that the 32mm down pipe and narrow tail pipe will be too restrictive. Asked most of these questions before fitting mine just so I had some idea of their thinking on their kit...
Posted: Thu Aug 27, 2009 9:26 pm
by rog60
bristolmod wrote:As I understand it, the downpipe section for TV200 was the same as all other S3's
So does mine.......out of the garage :D :D :D :D
I believe the TV200 silencer was replaced by the SX150/GP125/GP200 silencer, initially because of fracturing the main bracket and later in 1970, to comply with new vehicle noise regulations. Part nos:- Exhaust pipe 19518010 and silencer 19518510.
Early S3 models (except TV200) used a similar silencer 19918060 with a mushroom baffle on the entry pipe.
Both of the former silencers are believed to have the same performance.
Need a new anorak now :!: :!: :!: :mrgreen: :mrgreen: :mrgreen:
