Page 1 of 4
Porting tools....???
Posted: Mon Aug 24, 2009 2:22 pm
by J1MS
I need to replace my old right angled hand piece, Its a Foredom which works off a pendulum motor and flex drive with a foot control, but it's now worn out. Question is what else is available and does it fit the same drive or is a complete new setup needed... Anyone..??
Re: Porting tools....???
Posted: Mon Aug 24, 2009 2:46 pm
by Powolotti
http://cgi.ebay.com/Right-Angle-Handpie ... .m63.l1177
it seems to fit on the foredom flex drive, but looks deeper and i´m not sure if it´s suitable for our diameters...
Posted: Mon Aug 24, 2009 2:59 pm
by J1MS
Looks a little too large. I will take a pic of the porting tool I wish to replace and post it up here. I bought it in 83 for about £80 new. A simlar hand piece today is about £ 250+ the dreaded VAT... Ouch .....
Posted: Mon Aug 24, 2009 6:48 pm
by J1MS
This is a pic of my right angle porting tool... Used mainly for tidying up transfers in the bore or sometimes adding boost ports, but its broken.... anyone know of a good alternative to this type, as mine has a habit of wearing parts out (bearings and bevel drive gears not to mention replacing collets as they are a little fragile when used at the wrong angle... Its past its sell by date now and needs replacing... Anyone Please..?? otherwise its another one of these, and see how long it lasts and these are not cheap..!!
I could do with it to finish this off as the port edges in the bore dont quite line up about Two degrees between transfers on one side to the other and one of the smaller transfers is a little strangled in the bore... Not going to be fa fast TS just a mild tune to port entries blend and flow reeds but a little tidy in the bore would help on this barrel... Work in progress.
Posted: Mon Aug 24, 2009 9:03 pm
by guygrrr
Posted: Mon Aug 24, 2009 10:50 pm
by J1MS
I have emailed a couple of companies to get some feed back on their products, if their products are of any use, I will post them on here... just incase anyone else needs a replacement handpiece or wants to start porting barrels themselves, as thats what this site is all about, "tuning scooters" so if its of any use at all, I will put it on here for all to see.....
Posted: Sat Aug 29, 2009 12:24 am
by J1MS
Found this... http://www.artcotools.com/nsk-espert-br ... c-366.html but by the time the hand pieces are added in its near to $2000 thats quite expensive...
So it looks like I might buy a new one of these... http://www.moleroda.com/acatalog/Foredo ... html#a4631 looking for the best price now... But I dont know if I will have to pay import duty if I buy one from the States...?? they are usually cheaper from the States..!!
This could be very usefull... http://www.artcotools.com/foredom-to-ns ... 16890.html .... as it seems to allow the use of the higher quality NSK hand pieces, with the cheaper foredom motor & flex drive... The NSK hand pieces are classed as heavy duty use... the Foredom hand piece is a little less robust...
Which should allow it to be used with these... http://www.artcotools.com/nsk-90-angle- ... 16337.html ... http://www.artcotools.com/nsk-45-angle- ... 16338.html
Posted: Sat Sep 05, 2009 10:25 pm
by Ancillotti
I've been looking for a similar tool for quite a while now.
I've got a Dremel, Proxion 90deg, air die grinders and a guard free router, but internal bore work is still difficult.
J1MS have you had the Fordom since '83 or just the head? I've killed a few flexidrives over the years and would like to find something that will last, but not cost too much. The Foredom looks a decent enough price but I'd like to see it last for at least a dozen cylinders to justify the cost, or do I need to be considering some of the dearer units?
Hope somone can shed some light onto this.
Posted: Sat Sep 05, 2009 11:25 pm
by J1MS
I have a couple of small straight hand pieces some nearly as thin as a pencil, but the right angled hand piece is not actually a Fordom... My mistake...
Ive had it for years but because it was wearing out, I've not given it much use lately, It still works but the drive inside the shaft of the handset keeps failing, besides that the bearings and bevel gears are worn...
The reason I thought it was a Foredom is I had been looking for a replacement, seen the foredom, and thought that's the same as mine... but the fixing to the flex drive is different but its very similar other than that... I will photograph it tomorrow on its shaft drive with the Motor connected...
I got this one of a lad that once raced for Leeds Central, called... Peter Rutherford... he supplied a couple of the lads that raced with these at a good discount... Chiselspeed had one of these many years ago... Mine uses a large 1/3 HP motor which is reversible & has a foot control... I bought this back in the early 80's and the straight hand pieces just turned up over the years... The 90 degree hand piece I have had for about 25 years... Its had alot of use but not much use left in it now... I have ordered a replacement and some other bits & pieces. I'm just waiting for the postman now...
I will probably repair the hand piece and keep it using it just for roughing out Transfers in the bore...
Posted: Sun Sep 06, 2009 1:31 pm
by sean brady scooters
i,ve just got a new one from" SNAP ON.".........
its the "blue point"......model AT1070RA......right angle pencil die grinder...
it also says on it.......90psi max.......S/N 07320242. CE taiwan......
70,000 RPM........ :shock:
think it was £120.
will put some pics up later......with the other bits i use..........
one of my old die grinders (snap on again).....which was well worn out after 20 years use.....
has been sent off and fully rebuilt/reconned for me by snap on.......got it back the other day........and they only charged me £40..........great value ....especially if its lasts another 20 years............ :D
