which lens pattern - CEV or Aprilia ?
Piatti
Hi,
which back light lens do I need or order for this type of casting,
CEV or Aprilia ?
Also is there a gasket between the lens and the bulb holder ?
regards
Piatti
I think either will fit, hence the two pairs of holes, I have CEV on mine.
There is a plastic gasket in between.
Hope this helps.
its the corrello (spell check :lol: )that wont fit as it is angled at the back
rog60
Main scooter: Indian GP200
RICSPEED wrote:its the corrello (spell check :lol: )that wont fit as it is angled at the back
Is that the one with the integral reflector..............
i think they all do dont they?
Yes
Piatti, any use? :?
Piatti
Thanks for all the replies, the actual light housing has two holes on each side so will accept either a CEV or Aprilla type lens.
The angled type is the one which wont fit ( corrello )
I re-used my original reflector which sits in between the light housing and rear light lens, this had
holes directly in the middle which indicated that I needed a CEV type lens.
There is also a rear lens gasket which goes between rear lens and reflector,
I'll post some pics up when i get a minute
cheers
Piatti
