good cheap kit?
Posted: Fri Aug 21, 2009 5:55 pm
i will soon be the proud owner of a gp 200 and just wondering whats the best cheap way to get a bit more umph with out major surgery or expense
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
happy days whats all this stage four talk tho using the standerd barrel?sean brady scooters wrote:simple.........cut 3mm off piston skirt (on inlet side)...........
Juan wrote:f@@k me Joe, you don't half seek out strife pal.![]()
The SIL barrels are "stage 4" out of the box mate.
I was going to do this to my GP150 with 175 kit fitted and a mate offered to do it in work for me but when I got it back he had done it on a Lathe and taken 3mm of all the way roundsean brady scooters wrote:simple.........cut 3mm off piston skirt (on inlet side)...........
Lazarus wrote:I was going to do this to my GP150 with 175 kit fitted and a mate offered to do it in work for me but when I got it back he had done it on a Lathe and taken 3mm of all the way roundsean brady scooters wrote:simple.........cut 3mm off piston skirt (on inlet side)...........Plus he took 1mm of the top of the barrel.
But on fitting it and road testing it it flew with 6mph better top end (67mph sat nav ) and lots more mid range I was happy as hell![]()
Then 9 weeks ago it was pinched :flaming: and only tonight the insurance said the cheque is in the post so my next Lammy will be a Li 150 special with 175 kit again but this time ill just cut one side by hand.![]()
Will I still get the same results there abouts![]()
I only did it last time because I read about it on here and in a shop and fancied a cheep boost in power
