cam lam hub 140 quid???
cezeta
i had an italian innocenti gp one crack on me recently so was looking for something stronger.
so....are these worth the money?
wezly
im assuming this is the one tino has reproduced for the twin, in which case would make it good value, same spec as the spanish ones
wezly
the one pictured is not the actual one btw
cezeta
i thought the one for the twin was offset?
cezeta wrote:i thought the one for the twin was offset?
I think it was the rims were that were offset.
This hub makes genuine Spanish ones cheap.
cezeta
if you saw the multiple cracks through my hub and brake lining and consider the possible consequences :shock: :cry:
im getting old....all this safe thinking :roll:
