Page 1 of 2
rapido 250 what set up ?
Posted: Tue Aug 18, 2009 6:37 pm
by king of the hill
just bought myself a rapido 250 , wondering what setup you guys are using ?
i want torque rally going power , no crazy revving monster !
suggestions welcome
greetz
tim
Re: rapido 250 what set up ?
Posted: Tue Aug 18, 2009 7:52 pm
by tavspeed
hi,running mine with a scorpion pipe,tmx 35,inlet manifold matched to barrel,transfers on casing and barrell matched,li 150 box,16 tooth front sprocket,,timing strobed at 16 deg,squish 1.5mm,its a revvy mutha with the power coming in at about 5500rpm,did 22.3 bhp and 14.63 ft.lbs on scootereroticas dyno,if you are after a tourer,similar set up with a jl3 exhaust,cheers all.
Posted: Tue Aug 18, 2009 8:12 pm
by 2439sean
hi im running a jl3 with 34mm delly gp200 gear box with 19 / 48 sprockets 20bhp 14lbs of torque dyno at chiselspeed
Posted: Wed Aug 19, 2009 6:21 pm
by king of the hill
thanks for the reply guys ,
might even build one with a 48mm clubman insted of expansion exhaust , anybody used the
rapido 250 with a 48mm clubman ?
greetz
tim
Posted: Wed Aug 19, 2009 8:20 pm
by CT.
@ tavspead & 2439sean, do you have the race or classic version and is there any extra porting?
Thanks.
Posted: Wed Aug 19, 2009 8:29 pm
by mark
i use with an ancillotti clubman ,35tmx and its crap with a capital p
Posted: Wed Aug 19, 2009 8:41 pm
by king of the hill
mark , thanks for the comments on the clubman
ct , it seems mines a " race " , no idea what the difference with the classic is .
more info welcome ,
greetz
tim
Posted: Wed Aug 19, 2009 8:52 pm
by mark
i keep meaning to fit my mk1 pm but never have enuff time :oops:
mine will pull a trailer with 60 kilo and a weeks worthing of clothing for me and wifey combined weight bout 30 stone at 65mph(gps) all day at half throttle but thats it .
Posted: Wed Aug 19, 2009 9:02 pm
by CT.
Mark, I think AF now do a 'Classic' version as they did with the Rapido 225's which has more consevative port timing.
Posted: Thu Aug 20, 2009 1:30 am
by corrado
king of the hill wrote: i want torque rally going power , no crazy revving monster !
Then you should have bought the classic and not the race.
I'm building one at the moment and plan on using a TM24 and the new 48mm clubman, with tall(ish) gearing.
