New SIL engine...
Posted: Mon Aug 17, 2009 4:26 pm
by J1MS
Just thought I would post to say how good this one was, compaired to the last one I stripped down... From the same supplier... this one has held no horrors, just a little swarf in the engine oil, but no grit... The crank is good, cylinder head no faults this time... But the barrel is a little tattier than the last.... So maybe there are still some good ones to be had... :)
Re: New SIL engine...
Posted: Mon Aug 17, 2009 7:04 pm
by sponge bob
I think it all depends on what day it is assembled , you may have a Tuesday or Wednsday one there but if you are unlucky to get a Monday or a Friday afternoon one i think they may just be thrown together by a very bored or drunk mechanic !! Just my oppinion but it would explain some of the s**t that some times come through :D
Posted: Tue Aug 18, 2009 2:13 pm
by shocky
what was the squish like and the drive sprocket / spider clearance , and endplate clearance this is the 3 areas ive found problems
Posted: Tue Aug 18, 2009 2:15 pm
by shocky
just seen 4.5 mm :shock:
