cutdown rear runners
partly to get a bit more travel on my rearset brake, but mostly cos I like the look [reminded by sp1v's avatar], I am planning to fit some rear pegs and just have some small runners to cover the frame and retain the bridge piece neatly.
easist to just cut and adapt a set of runners, or is it better to make some from scratch ?
are originals strong enough with only being supported at the front ? I would use them when two-up and operate my rear brake with my heel. I was thinking I could make some from thicker steel... or would that be a lot of unnecessary fabrication ?
noggin1969
Beedspeed do a pair in stainless for £14
Has a mind full of useless s**t and isn't afraid to use it !
you could use the runners and adapt if you want but you may want to bolt a support to the stand cross member if you intend to put any weight on them though
Stokie
I've got a pair you can borrow Byron, try them out and decide if they're any good. If they are you can just copy them.
They're 'aged' too so should look OK on your scooter ! ;)
Do you want me to go and dig them out of the shed ?
Stokie wrote:I've got a pair you can borrow Byron, try them out and decide if they're any good. If they are you can just copy them.
aw cheers mate, that's very generous of you.
and i still owe you for sending me that template for my Mikeck bracket.
don't go digging just yet, I'll see if i can find any locally first.
I'd probably rather not cut into mine if i can avoid it, just in case I end up prefering it with complete runners. someone's gotta have a pair sitting unloved in a shed around here.
and remember to get in touch if you're working over this way.
I've got a pair of Indian runners you can have to hack about for nowt Byron, Garboldishan too far?
coln
coaster wrote:I've got a pair of Indian runners you can have to hack about for nowt Byron, Garboldishan too far?
coln
I think not, I don't know exactly where that is, but I've seen it on roadsigns not far from me
you about at the weekend Colin ?
I'll pm you my mobile.
thanks a lot 8-)
Yes I'm in Norfolk this weekend, Garboldisham is on the B1068 half way between Thetford and Diss.
colin
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 73 guests
