Which carb for my 175 engine?
Posted: Sun Aug 16, 2009 1:06 pm
by wax
My Ts1 240 engine lost compression the other week on the way to 'run to the scrum', leaving me high and dry for an engine for IOW. I have been spending some cash to get my 175 engine ready, incase JB can not get my barrel re-plated in time. The problem is that i am not sure which carb to go for. I have a stage 4 175 kit, an Ancilotti and elect ign kit. I want ti fit an Imola kit eventually, over winter, so i want a carb the will work with both the 175 kit and Imola. I really want one of them Mikuni TM24 carb kits (i want to run some kind of filter, but not an air box). I will use this engine to pootle round town and the odd rally, so fuel economy is an issue. Will a mikuni be over the top for this mild engine? Would i be better with a 25 / 26mm Dellorto? Funds are tight and i dont really want to spend money / time on a dyno run. Would jets be more readily available for dellortos? Your options would help.
Re: Which carb for my 175 engine?
Posted: Sun Aug 16, 2009 1:34 pm
by goldeneye
mmmmm. maybe you could just buy a 22mm jetex and manifold, and run that on your cast 175 for now, they are only about 25 quid, and save your money for a 30 mil dellorto or similar for when you imola it? that way, you can pootle around, and still have some dosh for the winter rebuild.
Posted: Sun Aug 16, 2009 7:21 pm
by soulsurfer
....or maybe a PWK OKO 24mm
Posted: Sun Aug 16, 2009 9:34 pm
by Soulpunk
get a cheap 22mil jetex and buy dellorto jets for it for the setup.
quality is not always on top, so it can be loads cheaper to buy one from a local dealer
for 35.- (exchange in case of mess) than on ebay.
for an imola kit, sell the jetex and get a mikuni or dello flatside.
DO NOT BUY A KOSO / PWK CHEAPO CARB.
why?
a) with all the money for jetting stuff and the adjustment stuff you can buy a genuine
mikuni or keihin carb.
b) bad quality. absolutely incomparable to genuine keihin and mikuni carbs.
Posted: Sun Aug 16, 2009 10:28 pm
by Soulpunk
DO NOT BUY A KOSO / PWK CARB.
why?
Posted: Mon Aug 17, 2009 7:32 am
by soulsurfer
why?
Worked fine on my 175 with the supplied jets and needles as it has on many others and recommended by a very respected engine builder.
Posted: Mon Aug 17, 2009 8:38 am
by red ghost
This is all you need and this is the place to get it from,buy it once and be done with it.
http://jet200.com/catalog/product_info. ... cts_id=124
Posted: Mon Aug 17, 2009 8:40 am
by red ghost
TM24 ultimate kit from Jet200 Performance, fantastic carb and Mark is a great guy to deal with. I even nominate him for 'dealer of the year'
Posted: Wed Aug 19, 2009 7:08 pm
by wax
I really want the 24mm tm carb, so may just bung on my 20mm standard one for the IOW and then do a re-build over the winter. Thanks for the advice
