Page 1 of 2
Gear Selector Arm Problem
Posted: Thu Aug 13, 2009 9:06 pm
by Bilko
Trying to get the gear selector arm to line up and not having any joy.
Anyone got a sollution or do I need a new selector arm?
Re: Gear Selector Arm Problem
Posted: Fri Aug 14, 2009 2:47 pm
by Bilko
I've tried the method in Sticky's book on page 70 (last paragraph) and I can get it to 10mm or 0mm, but I can't get it to 5mm when I move the arm by one splind either way.
Posted: Sat Aug 15, 2009 2:10 pm
by jonny snatchsniffer
can you select all the gears when rod and trunnion are in ?
are the splines different alighnment from li to gp models, could it be that the 1 piece arm fits different selectors in the engine to the 2 piece ?
Posted: Sat Aug 15, 2009 6:00 pm
by Bilko
I haven't got that far with the engine build yet.
Here's as close as I can get
Posted: Sun Aug 16, 2009 12:45 am
by byron
just come in from doing this on an Indian 200 casing
what gear is it in in your pic ?
I generally go for the putting it into second gear and making sure the selector arm is at right angle method, also on page 70.
is your layshaft pulled into place with the correct torque already ?
Posted: Sun Aug 16, 2009 1:08 am
by corrado
byron wrote:just come in from doing this on an Indian 200 casing
I think that is 2nd gear but if he moves it one spline it goes the same distance past the 90 degree point on the other side.
Posted: Sun Aug 16, 2009 8:15 am
by red ghost
I have a cat (well wife's actually) that drops hair everywhere and it covers my scoot all over especially the greasy parts. Effin annoying,I'm allergic to cats and if I didn't have a conscience,I'd make use of a plastic bag and a brick.
Sorry, just noticed the fur in the above pic and could relate to it.
Posted: Sun Aug 16, 2009 12:49 pm
by Bilko
You don't work for CSI do you? They are indeed pussy hairs.
Posted: Sun Aug 16, 2009 4:22 pm
by dirtyhandslopez
Bilko wrote:You don't work for CSI do you? They are indeed pussy hairs.
Odd that. I usually find them to be thicker and curlier. Old pussy is it?
Posted: Sun Aug 16, 2009 4:59 pm
by goldeneye
sure its not just a frayed cable, and not pussy hair? can be very similar in the dark you know..........................
