What squish ?
Posted: Thu Aug 13, 2009 7:32 am
by sponge bob
What is the correct size of squish on a Indian stage 4 200, as i have just been told that 2.5 mm is correct as that is what i have at the moment as was about to take it down to 1.5 . Not from the most reliable source but just thought i would double check before i re build the engine.
Re: What squish ?
Posted: Thu Aug 13, 2009 7:59 am
by Tosh
sponge bob wrote:What is the correct size of squish on a Indian stage 4 200, as i have just been told that 2.5 mm is correct as that is what i have at the moment as was about to take it down to 1.5 . Not from the most reliable source but just thought i would double check before i re build the engine.
checked mine when new it was 3.0 re set to 1.5 still running in only done 85miles but going strong at mo
paul
Re: What squish ?
Posted: Thu Aug 13, 2009 12:59 pm
by J1MS
Below 1.5 and the engine shouldn't detonate. But 3 mmis large enough to loose a little power as gas trapped at the end burns to late to make any power
Re: What squish ?
Posted: Sun Aug 16, 2009 10:30 pm
by J1MS
Just stripped another new SIL 200 (Donor Engine for a TS1)... But prior to taking it apart I thought I would check the squish...... It was 4.5mm... :shocking: Now that's what I call excessive
Re: What squish ?
Posted: Mon Aug 17, 2009 7:48 am
by sidebottom
J1MS wrote:Just stripped another new SIL 200 (Donor Engine for a TS1)... But prior to taking it apart I thought I would check the squish...... It was 4.5mm... :shocking: Now that's what I call excessive
Surely thats a record unless anyone knows different
