Page 1 of 2
piston holing caused by exhaust design....explain please?
Posted: Fri Aug 07, 2009 6:43 pm
by cezeta
i have heard that some
pipes cause piston holing. how is this caused? is it a suck it out but not back in - timing kind of glitch. anyone understand this and can shed some light on it?
i have not got a specific problem......just want to look good when i explain it to someone else some day
Re: piston holing......can someone explain please
Posted: Fri Aug 07, 2009 10:01 pm
by jonny snatchsniffer
can make it run lean and detonate holing the piston
Posted: Fri Aug 07, 2009 10:17 pm
by cezeta
jonny snatchsniffer wrote:can make it run lean and detonate holing the piston
well thought out explanation
Posted: Sat Aug 08, 2009 4:46 pm
by cezeta
MMMM, no body know?
Posted: Sat Aug 08, 2009 5:23 pm
by Bilko
I thought the sniffer of snatches replied?
That's the way I thought it worked.
Posted: Sat Aug 08, 2009 5:27 pm
by sean brady scooters
me too.........
although i would just add that whenever swapping pipes (especially to a more efficient one).............re jetting should be done to suit.
Posted: Sat Aug 08, 2009 5:36 pm
by Bilko
I've always rejetted or at least done a few plug chops. Just to make sure.
Posted: Sat Aug 08, 2009 5:38 pm
by coaster
Is it possible for some pipes to cause a weak spot that's hard to dial/impossible to out
Posted: Sat Aug 08, 2009 7:11 pm
by cezeta
coaster wrote:Is it possible for some pipes to cause a weak spot that's hard to dial/impossible to out
yes this was the line i was thinking, no disrespect chaps but i was looking for a bit more depth to the theory involving pulse timing exit tube diamiters ect.
just curioius really to what is going on to cause these problems
Posted: Sat Aug 08, 2009 7:22 pm
by soulsurfer
Have been wondering about this myself, also does the exhaust material play a part?
