Pressure Plate For Foxhat??
Posted: Thu Aug 06, 2009 6:50 pm
by soulsurfer
Been getting some drag on my Foxhat clutch, so stripped it to check and I only have around 1-1,5mm movement in the plates, which isn't enough, this is even without springs fitted. The pressure plate is Innocenti with the rod fitting into the xmas tree. Is this type necessary for this xmas tree or is there a better pressure plate to use, Surflex or MB??
Re: Pressure Plate For Foxhat??
Posted: Thu Aug 06, 2009 9:54 pm
by drunkmunkey6969
Winco pressure plate available from AF.
Posted: Thu Aug 06, 2009 10:48 pm
by soulsurfer
drunkmunkey6969 wrote:Winco pressure plate available from AF.
Really? Not heard of that one :?
Which clutch plates are recommended for this set-up these days?
