Series 3 seat
Posted: Wed Aug 05, 2009 4:56 pm
by Snails
Hi
Can someone identify this seat and which catch is needed? Any pictures of the catch needed would be much appreciated as would anywhere that sells them
Re: Series 3 seat
Posted: Wed Aug 05, 2009 4:57 pm
by Snails
another image
Re: Series 3 seat
Posted: Wed Aug 05, 2009 11:53 pm
by rog60
Looks like the Serveta one which had a catch akin to the Vespa one????
Re: Series 3 seat
Posted: Thu Aug 06, 2009 10:04 am
by Soulpunk
its the first type of a serveta lince seat : springs, rear p-range lock, "lambretta" printed in white over lock on back.
it locks in a p-range-pin. but pin must be higher mounted. originally its a p-range pin welded on a tin-subframe which is screwed on the frame on the 2 original holes.
cut a little piece of steel , drill 2 holes, weld a long cylinder-stud m8 in the middle and screw a
p-range pin in it...
try totally scooters first. they have a wide range of serveta parts.
or try allstyles scooters. they also might have it.
(but make shure you get the correct one of the 2 variants)
Re: Series 3 seat
Posted: Fri Aug 07, 2009 10:30 am
by Snails
Thanks very much for all the information
