mikuni jetting for ts1 225
Posted: Sun Aug 02, 2009 11:14 pm
hi,new to the site so maybe my
questions have been answered before but grateful for any help,with jetting for a ts1 225
i have a mikuni 35mm flat slide similar to the tmx in shape has no markings ,it is a little bit shorter and with an angled down draught,with normal joined floats
it looks to be a power jet type
on the front intake lower it has 1open & 2 jets , upper front has 1open which is supplied by a tube going to the lower bowl. just above the bowl on the front is a white plastic tube connector which supplies the jets on the front lower and the slow running or pilot jet in the bowl ,it has an air screw on the side. so any help in identifying what atomiser
main jet
pilot / slow running
needle. And what to do about the power jets :cheers soupy
main jet
