Page 1 of 2
whats causing this?
Posted: Wed Jul 29, 2009 6:30 pm
by sydduckett
Was doing a plug test (black) when i noticed that the cooling fins were a white colour from the back to nearly the front. It comes off when rubbed and then goes powdery? Had only been out for a short blast so im not sure if it has been this way for a while or not. fisrt time i have been out since sunday when i done about 80 miles and did give it some welly.. :o
its an AF RB kit and is running well at the mo. does anyone know whats causing this and is it anything i need to worry about?
Ta
Sef
Re: whats causing this?
Posted: Wed Jul 29, 2009 6:54 pm
by soulsurfer
Was it wet or damp last Sunday, or sitting damp since you parked it up?
Posted: Wed Jul 29, 2009 7:01 pm
by Ian Hepworth
Your head cowl is cracking.
Posted: Wed Jul 29, 2009 7:24 pm
by red ghost
Battery overflow tube floating around the cylinder, leaking, causing the acid to eat the aluminium?
Posted: Wed Jul 29, 2009 8:11 pm
by sydduckett
Do i not like Me Hepworths answer... :o Can you explain why you think its cracking and what would cause this?
Ta
Sef
Posted: Wed Jul 29, 2009 8:17 pm
by rog60
sydduckett wrote:Do i not like Me Hepworths answer... :o Can you explain why you think its cracking and what would cause this?
Ta
Sef
To me, there seems to be a small hairline crack in the cowl at the top left corner of the air outlet??
Posted: Wed Jul 29, 2009 8:30 pm
by sydduckett
Just checked and there is about a 1 cm crack in the angle of the cowelling. I may be being thick but why would this cause the fins to go white. Like i said you can scrape it off back to the metal...
Posted: Wed Jul 29, 2009 8:32 pm
by sydduckett
Its a non-batt model and its kept garaged, did give it a good wash on sunday though and may have ben a little over zelous when cleaning round case and tins..Would water cause this to happen?
Posted: Wed Jul 29, 2009 8:59 pm
by byron
sydduckett wrote:I...did give it a good wash on sunday though and may have ben a little over zelous when cleaning round case and tins..Would water cause this to happen?
quite probably. I believe the cowling remark was just an observation, rather than suggesting a cause as to your whiteness. stainless steel is it ?
Posted: Wed Jul 29, 2009 9:17 pm
by sydduckett
Yeah its stainless, read the first post wrong as in head cracked...panik over
